[GRASSGUI] Re: [GRASS-dev] new python gui
Michael Barton
michael.barton at asu.edu
Mon Mar 26 11:57:27 EDT 2007
On 3/26/07 12:34 AM, "Massimo Di Stefano" <massimodisasha at yahoo.it> wrote:
>> Which command is a problem?
> this is what i've for r.slope.aspect :
> http://img291.imageshack.us/img291/3842/immagine7cp9.png
> and for r.watershed :
> http://img134.imageshack.us/img134/3726/immagine10li0.png
It looks like both of these are fixed this morning.
> i'm really intersted about a "redrawing feature" in the same monitor...
> can i explain...
> just like :
> d.mon x0 ;
> d.rast map1_temp_1 ;
> d.mon x1 ;
> d.rast map2_temp1 ;
> d.mon select=x0 ; d.erase ; d.rast map1_temp2 ;
> d.mon select=x1 ; d.erase ; d.rast map2_temp2 ;
> ..... again for temp_1>....>n
> but
> when i use
> the command "p.mon" it open olways new monitor,
> (i cant "select" monitor for a "redrawing" process)
> seems that in "p.mon" the other option( stop, select, unlook) are
> not available.
I haven't worked with the convenience scripts p.mon etc.
However, this is certainly possible from the GIS Manager window.
> is this a common problem ?
> thanks for ant suggestion about!
> regards,
> Massimo.
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
More information about the grass-gui
