[GRASSGUI] graphic overlays
Mon Mar 26 15:59:43 EDT 2007
Moritz Lennert wrote:
> > there are precedents. I agree that we always need to minimize dependencies
> > as much as possible. But some are unavoidable, or at least highly desirable.
> I my understanding, the issue is not about dependencies, but about
> trying to avoid diverging development of two versions of GRASS: CLI and
> GUI. If we start adding more and more features to the GUI which are not
> available on the CLI, people might be obliged to use the GUI to access a
> specific feature, just because it was easier to code this for the GUI
> than for the CLI, and so noone bothered for the latter.
> In my eyes, the GUI should be a convenience, not an obligation.
FWIW, the above is essentially my position also.
> The examples you cited for justifying going directly through the GUI are
> all doable in the modules directly. It is obvious that we are more
> limited in developer power in C (although seeing the speed at which you
> learned tcltk and python, I don't think it would take you very long to
> get the gist of C ;-), but these are typically "small", well
> circumscribed tasks which we can try to tackle through Google summers of
> code, or even try to get institutions which use GRASS to contribute some
> development financing for... It might not be as fast as doing it through
> the GUI, but the final added value will be higher, IMHO.
Alternatives to C include using d.graph or creating Python bindings
for the raster/display libraries.
More information about the grass-gui mailing list
