[GRASSGUI] Re: [grass-addons] r363 - trunk/grassaddons/gui
Thu Mar 29 22:58:26 EDT 2007
Michael Barton wrote:
> I just copied the format in the current gis.m script. Without this, it is
> running modally. How would you recommend changing it?
Just remove the "&"s. If you want it to run in the background, type
"wxgrass &".
Note that GUI applications typically don't put themselves into the
background automatically. If you want them to run in the background,
you have to add the "&" yourself.
Sometimes you might want to wait for termination, e.g. to perform
clean-up. Having an application auto-background makes it impossible to
reliably detect termination.
More information about the grass-gui mailing list
