[GRASSGUI] GEM wizard in wxPython
Jachym Cepicky jachym.cepicky at gmail.com
Mon May 21 07:27:15 EDT 2007
Yann píše v Po 21. 05. 2007 v 18:12 +0700:
> Hi Jachym,
> Yes, the wget+parsing is tempting, i just need to figure out how to do all
> that...
> could you tell me where i can find your New Location Wizard, maybe I'll get a
> hint to do that for GEM.
well,
svn co https://grasssvn.itc.it/svn/grassaddons/trunk/grassaddons addons
cd addons/gui/
$EDITOR location_wizard.py
but it is a mess -  I need to clean this. try to take it really only as
an example.
Jachym
> Thanks
> Yann
> On Monday 21 May 2007 17:44, Jachym Cepicky wrote:
> > Hi,
> > basically, there are two possibilities: Use standard python packages or
> > using CLI commands. In current wxGRASS gui, commands are used, to avoid
> > new dependences. So, I would vote for some "wget+parsing" sollution.
> > For example, how to create wizard using wxpython, see wizard example in
> > wxpython demo
> > (http://prdownloads.sourceforge.net/wxpython/wxPython-demo-2.8.4.0.tar.bz2)
> > I put together nearly-working new location wizard, if you will be able
> > to follow the code.
> > Jachym
> > Yann píše v Po 21. 05. 2007 v 17:26 +0700:
> > > Hi all,
> > > Anybody could "mentor" a wxPython newbie into getting a GEM Wizard up and
> > > running?
> > > Aim:
> > > 1-List some predefined Extensions
> > > 2-Select any, then download it
> > > 3-Run Gem on the .tgz file downloaded (supposed you already are in root)
> > > Thanks
> > > Yann
Jachym Cepicky
e-mail: jachym.cepicky at gmail.com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
More information about the grass-gui mailing list
