[GRASSGUI] GEM wizard in wxPython
Michael Barton michael.barton at asu.edu
Mon May 21 14:57:09 EDT 2007
Jachym,
On my way to work, I was thinking that maybe we already have the tools we
need with g.proj. We should be able to create a default WIND file, PROJINFO,
and PROJUNITS files.
Michael
On 5/21/07 11:54 AM, "Jachym Cepicky" <jachym.cepicky at gmail.com> wrote:
> Hi,
> Michael Barton píše v Po 21. 05. 2007 v 08:18 -0700:
>> Jachym,
>> I did a bunch of update work on the wizard awhile back, so it is almost
>> done. Still waiting on some kind of update to g.proj or g.setproj to make
>> the manual location creation work. I guess we could just go ahead with the
>> epsg, georeferenced file, and related parts and ask again for an update to
>> make the other part work.
>> Michael
> while ago, I had to fix some bugs to :-) Yes, he have to make g.setproj
> more usable for our needs. I'll look at it
> Jachym
>> On 5/21/07 4:27 AM, "Jachym Cepicky" <jachym.cepicky at gmail.com> wrote:
>>> Hi,
>>> Yann píše v Po 21. 05. 2007 v 18:12 +0700:
>>>> Hi Jachym,
>>>> Yes, the wget+parsing is tempting, i just need to figure out how to do all
>>>> that...
>>>> could you tell me where i can find your New Location Wizard, maybe I'll get
>>>> a
>>>> hint to do that for GEM.
>>> well,
>>> svn co https://grasssvn.itc.it/svn/grassaddons/trunk/grassaddons addons
>>> cd addons/gui/
>>> $EDITOR location_wizard.py
>>> but it is a mess -  I need to clean this. try to take it really only as
>>> an example.
>>> Jachym
>>>> Thanks
>>>> Yann
>>>> On Monday 21 May 2007 17:44, Jachym Cepicky wrote:
>>>>> Hi,
>>>>> basically, there are two possibilities: Use standard python packages or
>>>>> using CLI commands. In current wxGRASS gui, commands are used, to avoid
>>>>> new dependences. So, I would vote for some "wget+parsing" sollution.
>>>>> For example, how to create wizard using wxpython, see wizard example in
>>>>> wxpython demo
(http://prdownloads.sourceforge.net/wxpython/wxPython-demo-2.8.4.0.tar.bz2>>>>>
>>>>> I put together nearly-working new location wizard, if you will be able
>>>>> to follow the code.
>>>>> Jachym
>>>>> Yann píše v Po 21. 05. 2007 v 17:26 +0700:
>>>>>> Hi all,
>>>>>> Anybody could "mentor" a wxPython newbie into getting a GEM Wizard up and
>>>>>> running?
>>>>>> Aim:
>>>>>> 1-List some predefined Extensions
>>>>>> 2-Select any, then download it
>>>>>> 3-Run Gem on the .tgz file downloaded (supposed you already are in root)
>>>>>> Thanks
>>>>>> Yann
>> __________________________________________
>> Michael Barton, Professor of Anthropology
>> School of Human Evolution & Social Change
>> Center for Social Dynamics & Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
phone: 480-965-6213
fax: 480-965-7671
More information about the grass-gui mailing list
