[GRASS-PSC] RFC: Module Option Parser
Scott Mitchell smitch at mac.com
Thu Dec 14 22:14:03 EST 2006
(1) Your proposed solution sounds good to me, but
(2) this discussion also sounds to me like the kind of thing that
might be better served on the dev list, for more potentially valuable
suggestions and broader consensus?  Seems to me that the PSC role
would be to break a stalemate if no consensus emerges, but I'm
assuming a relatively small number of potentially valuable
contributors are subscribed to this list.
I could be wrong...
Cheers,
Scott
On 14 Dec 2006, at 21:59, Brad Douglas wrote:
> I'm in the process of updating/upgrading the imagery libraries and
> modules.  I have run into a problem which I wish to simplify, but
> would
> require modification of lib/gis/parser.c, etc.
> I think we can all agree that i.ortho.photo is a mess and hasn't been
> able to evolve as the rest of GRASS has.  I want to remove as much
> interactivity as possible, but that creates a dilemma:
> A) I can break i.ortho.photo into 7-8 separate modules, or
> B) I can make it a single module by using the following structure:
> Option A does not set well with me and Markus has agreed,
> privately, due
> to the ever growing list of GRASS modules, so I need something a bit
> 'better'.
> - Create an Option that allows to select from a series of commands
> like
> v.build does:
>     tool_opt = G_define_option ();
>     tool_opt->key         = "tool";
>     tool_opt->type        = TYPE_STRING;
>     tool_opt->required    = YES;
>     tool_opt->multiple    = NO;
>     tool_opt->description = _("The ortho tool to use:\n"
>                 "\t\ttarget    - Target imagery location and mapset\n"
>                 "\t\tdem       - Digital Elevation Model (elevation)
> \n"
>                 "\t\tcamera    - Camera parameters\n"
>                 "\t\ttransform - Transformation parameters\n"
>                 "\t\texposure  - Exposure parameters\n"
>                 "\t\tparams    - Ortho photo parameters\n"
>                 "\t\trectify   - Rectify the ortho photo");
>     tool_opt->options     =
> "target,dem,camera,transform,exposure,params,rectify";
> ...but alter it a bit, namely changing the first line to:
> tool_opt = G_define_selection(), a new function.
> In order to make this work and keep the many options from spamming
> i.ortho.photo --help (as many of the above selections have multiple
> options that are not related to each other), I would like to
> propose the
> following changes:
> - Create a new function: G_define_selection ();
> - Add another option to G_define_option () that would link an
> option to
> a selection:
>     dem_opt = G_define_option ();
>     dem_opt->key           = "dem";
>     dem_opt->type          = TYPE_STRING;
>     dem_opt->required      = NO;
>     dem_opt->multiple      = NO;
>     dem_opt->description   = _("Digital Elevation Model");
> --> dem_opt->selection     = "dem";   <--- new option
> So...when I do 'i.ortho.photo --help', I get a list of selections to
> choose from.  When I do, 'i.ortho.photo select=dem --help', I only
> get a
> list of options associated with the "dem" selection (ie. dem_opt).
> Comments, suggestions, and better ideas are always welcome.
> Brad Douglas <rez touchofmadness com>                    KB8UYR/6
> Address: 37.493,-121.924 / WGS84    National Map Corps #TNMC-3785
> grass-psc mailing list
> grass-psc at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-psc
More information about the grass-psc mailing list
