[GRASS-PSC] [Motion] Approve Linda's student grant final report and issue the second payment
Martin Landa landa.martin at gmail.com
Wed Mar 9 07:17:31 PST 2022
+1 Martin
Dne so 5. 3. 2022 2:37 uživatel Helena Mitasova via grass-psc <
grass-psc at lists.osgeo.org> napsal:
> +1
> Helena
> On Mar 4, 2022, at 10:58 AM, Huidae Cho <grass4u at gmail.com> wrote:
> +1
> Huidae
> Huidae Cho, Ph.D., GISP
> GRASS GIS Developer
> https://idea.isnew.info/
> Sent from my phone
> On Fri, Mar 4, 2022, 9:21 AM Vaclav Petras <wenzeslaus at gmail.com> wrote:
>> +1 for Linda!
>> On Fri, Mar 4, 2022, 7:09 AM Markus Neteler <neteler at osgeo.org> wrote:
>>> +1 Markus
>>> Thanks Linda and mentors!
>>> On Thu, Mar 3, 2022 at 11:30 PM Veronica Andreo <veroandreo at gmail.com>
>>> wrote:
>>> > Dear PSC,
>>> > Linda has just completed her project for the student grant and
>>> submitted the final report (I FWD it here in case you missed it).
>>> > I hereby propose to approve her final report and issue the second half
>>> of the payment. Big thanks to Linda and her mentors for your work and
>>> commitment!
>>> > I start with my +1 !!
>>> > Vero
>>> > ---------- Forwarded message ---------
>>> > De: Linda Kladivová <L.Kladivova at seznam.cz>
>>> > Date: mié, 2 mar 2022 a las 19:19
>>> > Subject: [GRASS-dev] Final report for Mini project 2022: Redesigning a
>>> map display status bar combo box into a new settings dialog
>>> > To: <grass-dev at lists.osgeo.org>, <grass-user at lists.osgeo.org>
>>> > Hello everyone,
>>> > I am sending my final Mini Project report. The more detailed version
>>> with permanent links on GitHub PRs and with several screenshots can be
>>> found at the project wiki [1].
>>> > Abstract:
>>> > Especially for Single-Window GUI, the Map Display status bar needs to
>>> be lightened up a bit since in the case of opening more Map Display
>>> notebook pages the check box on the right side of the status bar gets
>>> shrunk. The solution is to remove the combo box in the status bar occupying
>>> too much space and implement a new Map Display settings dialog accessible
>>> from the top map display toolbar.
>>> > The state of the art BEFORE the start of Mini Project:
>>> > At this moment, the status bar at the bottom of the Map Display window
>>> consists of the text/widget section, the combo box, the mask and the check
>>> box. For the Single-Window GUI, the number of widgets must be reduced so
>>> that the check box on the right side of the status bar is not shrunk.
>>> > The state of the art AFTER Mini Project:
>>> > The new Map Display settings dialog is introduced. The main task of
>>> this dialog is to manage General Map Display settings and Statusbar
>>> settings. It implies that the status bar combobox is not needed anymore
>>> because we can find all Map Display settings including status bar
>>> customization in the new dialog.
>>> > Next Steps:
>>> > Other possible improvements related to status bar stuff could be:
>>> > Moving Projection page from GUI settings to the Map Display status bar
>>> settings
>>> > Adding context menu for status bar customization
>>> > Adding EPSG code label of current location to the main status bar
>>> > Merging „Go to coordinates X, Y“ and „Coordinates“ item into one widget
>>> > Permanent links and screenshots can be found at [2] and [3].
>>> > [1]
>>> https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar
>>> > [2]
>>> https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar#FinalReport
>>> > [3]
>>> https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/RedesigningStatusbar#BrandnewScreenshotsofMapDisplaySettingsdialog
>>> > Have a nice week,
>>> > Linda
>>> > _______________________________________________
>>> > grass-dev mailing list
>>> > https://lists.osgeo.org/mailman/listinfo/grass-dev
>>> > grass-psc mailing list
>>> > https://lists.osgeo.org/mailman/listinfo/grass-psc
>>> Markus Neteler, PhD
>>> https://www.mundialis.de - free data with free software
>>> https://grass.osgeo.org
>>> https://courses.neteler.org/blog
URL: <http://lists.osgeo.org/pipermail/grass-psc/attachments/20220309/df9cddb3/attachment.html>
More information about the grass-psc mailing list
