SOCCER LAB GRASS QA: 2 clones ( strings.c ) 0 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Apr 4 09:09:36 EDT 2006
Hello radim,
Threshold GRASS6 key metrics values at 2006-04-04 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/lib/gis/strings.c functions
G_strend (Begins at: 72 Ends at: 77)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
G_strcpy (Begins at: 79 Ends at: 86)
LOC:          |       8 |       |      OK |
metrics are OK
G_chrcpy (Begins at: 88 Ends at: 96)
ParamNBR:     |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
G_strncpy (Begins at: 98 Ends at: 106)
LOC:          |       9 |       |      OK |
metrics are OK
G_strmov (Begins at: 108 Ends at: 115)
LOC:          |       8 |       |      OK |
metrics are OK
G_chrmov (Begins at: 117 Ends at: 124)
LOC:          |       8 |       |      OK |
metrics are OK
G_strcat (Begins at: 126 Ends at: 130)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
G_chrcat (Begins at: 132 Ends at: 136)
LOC:          |       5 |       |      OK |
metrics are OK
G_strcasecmp (Begins at: 138 Ends at: 160)
Complexity:   |      10 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
G_strstr (Begins at: 163 Ends at: 185)
Complexity:   |       4 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
G_strdup (Begins at: 188 Ends at: 199)
CalledNBR:    |       3 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
G_strchg (Begins at: 202 Ends at: 227)
Complexity:   |       3 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
G_str_replace (Begins at: 229 Ends at: 300)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      72 |       |      OK |
metrics are OK
G_strip (Begins at: 302 Ends at: 347)
LOC:          |      46 |       |      OK |
metrics are OK
G_chop (Begins at: 349 Ends at: 374)
Complexity:   |       5 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
G_str_to_upper (Begins at: 381 Ends at: 392)
CalledNBR:    |       1 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
G_str_to_lower (Begins at: 400 Ends at: 411)
LOC:          |      12 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  G_strncpy  G_chrcpy
Brought to you by:
