SOCCER LAB GRASS QA: 1 clones ( main.c ) 1 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Apr 4 14:39:17 EDT 2006
Hello cho,
Threshold GRASS6 key metrics values at 2006-04-04 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/raster/r.in.ascii/main.c functions
main (Begins at: 14 Ends at: 248)
Complexity:   |      26 |    ** | Warning |
CalledNBR:    |      96 |   *** | MONSTER |
LOC:          |     235 |    ** | Warning |
1 metric are OUT OF RANGE!
file_cpy (Begins at: 251 Ends at: 277)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  file_cpy
Brought to you by:
