SOCCER LAB GRASS QA: 4 clones ( main.c main.c main.c ) 8 monsters and 6 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Apr 4 14:58:26 EDT 2006
Hello cho,
Threshold GRASS6 key metrics values at 2006-04-04 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/raster/r.in.gdal/main.c functions
main (Begins at: 40 Ends at: 547)
Complexity:   |      45 |   *** | MONSTER |
CalledNBR:    |     148 |   *** | MONSTER |
LOC:          |     508 |   *** | MONSTER |
3 metric are OUT OF RANGE!
SetupReprojector (Begins at: 553 Ends at: 606)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      54 |       |      OK |
metrics are OK
ImportBand (Begins at: 613 Ends at: 918)
Complexity:   |      34 |    ** | Warning |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      84 |   *** | MONSTER |
LOC:          |     306 |   *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
Brought to you by:
