SOCCER LAB GRASS QA: 3 clones ( main.c main.c ) 3 monsters and 3 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Apr 4 14:58:26 EDT 2006
Hello cho,
Threshold GRASS6 key metrics values at 2006-04-04 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/raster3d/r3.out.vtk/main.c functions
fatalError (Begins at: 62 Ends at: 79)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
setParams (Begins at: 85 Ends at: 193)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |     109 |       |      OK |
metrics are OK
OpenInputMap (Begins at: 199 Ends at: 214)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
CloseInputMap (Begins at: 220 Ends at: 226)
CalledNBR:    |       3 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
CheckInputMaps (Begins at: 232 Ends at: 307)
Complexity:   |      14 |       |      OK |
CalledNBR:    |      23 |       |      OK |
LOC:          |      76 |       |      OK |
metrics are OK
OpenWriteRGBMaps (Begins at: 313 Ends at: 382)
Complexity:   |      16 |     * |         |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      18 |       |      OK |
LOC:          |      70 |       |      OK |
metrics are OK
OpenWriteVectorMaps (Begins at: 387 Ends at: 457)
LOC:          |      71 |       |      OK |
metrics are OK
writeVTKStructuredPointHeader (Begins at: 463 Ends at: 517)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
writeVTKStructuredGridHeader (Begins at: 523 Ends at: 538)
CalledNBR:    |       8 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
writeVTKPoints (Begins at: 544 Ends at: 651)
Complexity:   |      15 |       |      OK |
LOC:          |     108 |       |      OK |
metrics are OK
writeVTKData (Begins at: 657 Ends at: 731)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      25 |       |      OK |
LOC:          |      75 |       |      OK |
metrics are OK
writeVTKRGBVoxelData (Begins at: 737 Ends at: 876)
Complexity:   |      18 |     * |         |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      36 |     * |         |
LOC:          |     140 |     * |         |
at least 1 values are close to an outlier please consider revising code
writeVTKVectorData (Begins at: 882 Ends at: 985)
CalledNBR:    |      24 |       |      OK |
LOC:          |     104 |       |      OK |
main (Begins at: 990 Ends at: 1150)
Complexity:   |      20 |     * |         |
CalledNBR:    |      55 |     * |         |
LOC:          |     161 |     * |         |
Clone analysis:
This file has 1 potentially cloned functions:
  OpenInputMap
Brought to you by:
