SOCCER LAB GRASS QA: no clones 0 monsters and 1 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Wed Apr 5 15:20:42 EDT 2006
Hello cho,
Threshold GRASS6 key metrics values at 2006-04-05 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     254 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/vector/v.in.dxf/add_line.c functions
add_line (Begins at: 8 Ends at: 104)
Complexity:   |      26 |    ** | Warning |
CalledNBR:    |      19 |       |      OK |
LOC:          |      97 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Brought to you by:
