SOCCER LAB GRASS QA: 6 clones ( Color_table.c ) 0 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Mon Apr 17 18:14:26 EDT 2006
Hello cedric,
Threshold GRASS6 key metrics values at 2006-04-17 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
ANALYSIS
./grass6/display/drivers/XDRIVER/Color_table.c functions
get_shifts (Begins at: 17 Ends at: 32)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
get_rgb_shifts (Begins at: 34 Ends at: 41)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
find_color_gray (Begins at: 43 Ends at: 48)
ParamNBR:     |       3 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
find_color_indexed (Begins at: 50 Ends at: 53)
LOC:          |       4 |       |      OK |
metrics are OK
find_color_rgb (Begins at: 55 Ends at: 62)
LOC:          |       8 |       |      OK |
metrics are OK
find_color (Begins at: 64 Ends at: 82)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
get_max_levels (Begins at: 84 Ends at: 104)
LOC:          |      21 |       |      OK |
metrics are OK
get_fewer_levels (Begins at: 106 Ends at: 127)
Complexity:   |       3 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
try_get_colors (Begins at: 129 Ends at: 162)
Complexity:   |       2 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
try_get_grays (Begins at: 164 Ends at: 191)
LOC:          |      28 |       |      OK |
metrics are OK
ramp_colormap (Begins at: 193 Ends at: 216)
LOC:          |      24 |       |      OK |
metrics are OK
init_color_table (Begins at: 218 Ends at: 310)
Complexity:   |      21 |     * |         |
CalledNBR:    |      15 |       |      OK |
LOC:          |      93 |       |      OK |
metrics are OK
XD_lookup_color (Begins at: 313 Ends at: 337)
CalledNBR:    |       2 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
XD_reset_color (Begins at: 339 Ends at: 363)
LOC:          |      25 |       |      OK |
metrics are OK
XD_Color_table_float (Begins at: 365 Ends at: 388)
CalledNBR:    |       5 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
XD_Color_table_fixed (Begins at: 389 Ends at: 403)
LOC:          |      15 |       |      OK |
metrics are OK
XD_get_table_type (Begins at: 405 Ends at: 408)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
This file has 6 potentially cloned functions:
  get_max_levels  try_get_colors  get_fewer_levels  get_shifts  ramp_colormap  find_color_rgb
Brought to you by:
