[GRASS-QA] SOCCER LAB GRASS QA: no clones 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Sat Apr 22 05:21:56 EDT 2006
Hello hamish,
ANALYSIS
raster/r.drain/main.c functions
main (Begins at: 68 Ends at: 444)
Complexity:   |      33 |    ** | Warning |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |     123 |   *** | MONSTER |
LOC:          |     377 |   *** | MONSTER |
3 metric are OUT OF RANGE!
drain (Begins at: 446 Ends at: 503)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-04-22 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
