[GRASS-QA] SOCCER LAB GRASS QA: no clones 3 monsters and 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri Apr 28 17:10:00 EDT 2006
Hello markus,
ANALYSIS
ps/ps.map/main.c functions
main (Begins at: 70 Ends at: 729)
Complexity:   |      96 |   *** | MONSTER |
CalledNBR:    |     231 |   *** | MONSTER |
LOC:          |     660 |   *** | MONSTER |
3 metric are OUT OF RANGE!
usage (Begins at: 733 Ends at: 737)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-04-28 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      78 |
LOC:                    40 |       182 |     256 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
