[GRASS-QA] GRASS QA: glynn | ./grass6/display/drivers/lib/Returns.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Aug 1 18:10:48 EDT 2006
Hello glynn,
ANALYSIS
display/drivers/lib/Returns.c functions
COM_Screen_left (Begins at: 4 Ends at: 7)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
COM_Screen_rite (Begins at: 9 Ends at: 12)
LOC:          |       4 |       |      OK |
metrics are OK
COM_Screen_bot (Begins at: 14 Ends at: 17)
LOC:          |       4 |       |      OK |
metrics are OK
COM_Screen_top (Begins at: 19 Ends at: 22)
LOC:          |       4 |       |      OK |
metrics are OK
COM_Get_num_colors (Begins at: 24 Ends at: 27)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-01 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
