[GRASS-QA] GRASS QA: soeren | ./grass6/raster/r.le/r.le.trace/main.c |no clones | 3 monsters | 5 warnings
Mon Aug 14 14:59:35 EDT 2006
Hello soeren,
ANALYSIS
raster/r.le/r.le.trace/main.c functions
main (Begins at: 40 Ends at: 106)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      29 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
set_map (Begins at: 108 Ends at: 148)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |       9 |       |      OK |
LOC:          |      41 |       |      OK |
at least 1 values are close to an outlier please consider revising code
show_patch (Begins at: 150 Ends at: 268)
Complexity:   |      23 |     * |         |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      48 |     * |         |
LOC:          |     119 |     * |         |
metrics are OK
patch_attr (Begins at: 273 Ends at: 318)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      46 |       |      OK |
metrics are OK
draw_patch (Begins at: 320 Ends at: 347)
LOC:          |      28 |       |      OK |
metrics are OK
scr_cell (Begins at: 349 Ends at: 362)
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
cell_clip_drv (Begins at: 364 Ends at: 483)
CalledNBR:    |      12 |       |      OK |
LOC:          |     120 |     * |         |
metrics are OK
cell_clip (Begins at: 490 Ends at: 711)
Complexity:   |      32 |    ** | Warning |
ParamNBR:     |       8 |    ** | Warning |
CalledNBR:    |      37 |     * |         |
LOC:          |     222 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
trace (Begins at: 719 Ends at: 836)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       2 |       |      OK |
LOC:          |     118 |     * |         |
metrics are OK
get_bd (Begins at: 838 Ends at: 1497)
Complexity:   |      70 |   *** | MONSTER |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      31 |       |      OK |
LOC:          |     660 |   *** | MONSTER |
3 metric are OUT OF RANGE!
yes_nb (Begins at: 1499 Ends at: 1630)
Complexity:   |      15 |       |      OK |
LOC:          |     132 |     * |         |
clockwise (Begins at: 1632 Ends at: 1640)
Complexity:   |       2 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-14 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
