[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/base/r3.info.main.c |no clones | 3 monsters | 0 warnings
Sat Aug 19 11:21:35 EDT 2006
Hello markus,
ANALYSIS
raster3d/base/r3.info.main.c functions
main (Begins at: 46 Ends at: 426)
Complexity:   |      47 |   *** | MONSTER |
CalledNBR:    |     196 |   *** | MONSTER |
LOC:          |     381 |   *** | MONSTER |
3 metric are OUT OF RANGE!
format_double (Begins at: 429 Ends at: 435)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
