[GRASS-QA] GRASS QA: markus | ./grass6/vector/lidar/v.lidar.edgedetection/edgedetection.c |no clones | 2 monsters | 0 warnings
Sat Aug 19 12:08:53 EDT 2006
Hello markus,
ANALYSIS
vector/lidar/v.lidar.edgedetection/edgedetection.c functions
edge_detection (Begins at: 11 Ends at: 89)
Complexity:   |       7 |       |      OK |
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |      32 |       |      OK |
LOC:          |      79 |       |      OK |
1 metric are OUT OF RANGE!
Get_Gradient (Begins at: 91 Ends at: 113)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
classification (Begins at: 115 Ends at: 285)
Complexity:   |      24 |     * |         |
ParamNBR:     |      16 |   *** | MONSTER |
CalledNBR:    |      61 |    ** | Warning |
LOC:          |     171 |     * |         |
Insert (Begins at: 287 Ends at: 300)
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       6 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
Insert_Interpolation (Begins at: 302 Ends at: 315)
LOC:          |      14 |       |      OK |
metrics are OK
UpDate (Begins at: 318 Ends at: 330)
CalledNBR:    |       4 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Select (Begins at: 332 Ends at: 374)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      22 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
Create_AuxEdge_Table (Begins at: 377 Ends at: 410)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      18 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
Create_Interpolation_Table (Begins at: 412 Ends at: 438)
CalledNBR:    |      14 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
