[GRASS-QA] GRASS QA: martinl | ./grass6/general/g.region/cmd/adjust.c |no clones | 0 monsters | 0 warnings
Sun Aug 20 10:58:09 EDT 2006
Hello martinl,
ANALYSIS
general/g.region/cmd/adjust.c functions
adjust_window (Begins at: 5 Ends at: 15)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-20 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
