[GRASS-QA] GRASS QA: markus | ./grass6/vector/lidar/lidarlib/raster.c |no clones | 2 monsters | 0 warnings
Sun Aug 20 14:32:16 EDT 2006
Hello markus,
ANALYSIS
vector/lidar/lidarlib/raster.c functions
P_Sparse_Points (Begins at: 15 Ends at: 174)
Complexity:   |      19 |     * |         |
ParamNBR:     |      18 |   *** | MONSTER |
CalledNBR:    |      70 |    ** | Warning |
LOC:          |     160 |     * |         |
1 metric are OUT OF RANGE!
P_Regular_Points (Begins at: 179 Ends at: 271)
Complexity:   |      11 |       |      OK |
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |       7 |       |      OK |
LOC:          |      93 |       |      OK |
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-20 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
