[GRASS-QA] GRASS QA: markus | ./grass6/vector/lidar/lidarlib/TcholBand.c |no clones | 0 monsters | 0 warnings
Tue Aug 22 16:26:04 EDT 2006
Hello markus,
ANALYSIS
vector/lidar/lidarlib/TcholBand.c functions
tcholDec (Begins at: 10 Ends at: 29)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
tcholSolve (Begins at: 34 Ends at: 67)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       5 |     * |         |
LOC:          |      34 |       |      OK |
metrics are OK
tcholSolve2 (Begins at: 74 Ends at: 97)
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
tcholInv (Begins at: 102 Ends at: 140)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
tcholSolveInv (Begins at: 145 Ends at: 201)
LOC:          |      57 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-22 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
