[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/r3.cross.rast/main.c |1 clones ( main.c main.c main.c main.c main.c main.c main.c main.c parser.c main.c )| 0 monsters | 1 warnings
Wed Aug 23 07:40:14 EDT 2006
Hello markus,
ANALYSIS
raster3d/r3.cross.rast/main.c functions
FatalError (Begins at: 48 Ends at: 68)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
SetParameter (Begins at: 74 Ends at: 101)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
G3dCrossRaster (Begins at: 108 Ends at: 237)
Complexity:   |      23 |     * |         |
CalledNBR:    |      30 |       |      OK |
LOC:          |     130 |     * |         |
metrics are OK
main (Begins at: 243 Ends at: 393)
CalledNBR:    |      62 |    ** | Warning |
LOC:          |     151 |     * |         |
at least 1 values are close to an outlier please consider revising code
CloseOutputMap (Begins at: 399 Ends at: 403)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  SetParameter
In raster3d/r3.cross.rast/main.c clones of  SetParameter are:
	raster3d/r3.to.rast/main.c  setParams
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
