[GRASS-QA] GRASS QA: markus | ./grass6/display/d.linegraph/linegraph.c |no clones | 2 monsters | 0 warnings
Wed Aug 23 07:40:07 EDT 2006
Hello markus,
ANALYSIS
display/d.linegraph/linegraph.c functions
main (Begins at: 36 Ends at: 589)
Complexity:   |      34 |    ** | Warning |
CalledNBR:    |     123 |   *** | MONSTER |
LOC:          |     554 |   *** | MONSTER |
2 metric are OUT OF RANGE!
rem (Begins at: 591 Ends at: 595)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
death (Begins at: 599 Ends at: 608)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
