[GRASS-QA] GRASS QA: glynn | ./grass6/lib/raster/com_io.c |no clones | 0 monsters | 0 warnings
Wed Aug 30 15:04:09 EDT 2006
Hello glynn,
ANALYSIS
lib/raster/com_io.c functions
init_transport (Begins at: 167 Ends at: 183)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
R_open_driver (Begins at: 185 Ends at: 189)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
R__open_quiet (Begins at: 191 Ends at: 195)
LOC:          |       5 |       |      OK |
metrics are OK
R_stabilize (Begins at: 197 Ends at: 200)
LOC:          |       4 |       |      OK |
metrics are OK
R_kill_driver (Begins at: 202 Ends at: 205)
LOC:          |       4 |       |      OK |
metrics are OK
R_close_driver (Begins at: 207 Ends at: 210)
LOC:          |       4 |       |      OK |
metrics are OK
R_release_driver (Begins at: 212 Ends at: 215)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-30 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
