[GRASS-QA] GRASS QA: glynn | ./grass6/lib/driver/font_freetype.c |no clones | 0 monsters | 0 warnings
Wed Aug 30 16:48:04 EDT 2006
Hello glynn,
ANALYSIS
lib/driver/font_freetype.c functions
font_init_freetype (Begins at: 7 Ends at: 12)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
font_init_charset (Begins at: 14 Ends at: 19)
LOC:          |       6 |       |      OK |
metrics are OK
font_get_freetype_name (Begins at: 21 Ends at: 24)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
font_get_charset (Begins at: 26 Ends at: 29)
LOC:          |       4 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-30 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     252 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
