[GRASS-QA] GRASS QA: brad | ./grass6/lib/gmath/lu.c |no clones | 0 monsters | 0 warnings
Sat Dec 9 13:54:20 EST 2006
Hello brad,
ANALYSIS
lib/gmath/lu.c functions
G_ludcmp (Begins at: 5 Ends at: 71)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
G_lubksb (Begins at: 75 Ends at: 100)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
