[GRASS-QA] GRASS QA: brad | ./grass6/lib/vask/V_exit.c |no clones | 0 monsters | 0 warnings
Sat Dec 9 13:54:20 EST 2006
Hello brad,
ANALYSIS
lib/vask/V_exit.c functions
V_exit (Begins at: 27 Ends at: 58)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
