[GRASS-QA] GRASS QA: brad | ./grass6/lib/imagery/fopen.c |no clones | 0 monsters | 0 warnings
Sat Dec 9 13:54:20 EST 2006
Hello brad,
ANALYSIS
lib/imagery/fopen.c functions
error (Begins at: 12 Ends at: 22)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
error2 (Begins at: 24 Ends at: 33)
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       3 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
I_fopen_group_file_new (Begins at: 36 Ends at: 50)
Complexity:   |       2 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
I_fopen_group_file_append (Begins at: 53 Ends at: 67)
LOC:          |      15 |       |      OK |
metrics are OK
I_fopen_group_file_old (Begins at: 70 Ends at: 91)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
I_fopen_subgroup_file_new (Begins at: 94 Ends at: 109)
ParamNBR:     |       3 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
I_fopen_subgroup_file_append (Begins at: 112 Ends at: 127)
LOC:          |      16 |       |      OK |
metrics are OK
I_fopen_subgroup_file_old (Begins at: 130 Ends at: 152)
LOC:          |      23 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
