[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.transect/parse_line.c |no clones | 0 monsters | 1 warnings
Sat Dec 9 13:54:32 EST 2006
Hello jachym,
ANALYSIS
raster/r.transect/parse_line.c functions
parse_line (Begins at: 10 Ends at: 45)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      12 |       |      OK |
LOC:          |      36 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
