[GRASS-QA] GRASS QA: jachym | ./grass6/raster/simwe/simlib/output.c |no clones | 3 monsters | 0 warnings
Sat Dec 9 13:54:32 EST 2006
Hello jachym,
ANALYSIS
raster/simwe/simlib/output.c functions
output_data (Begins at: 14 Ends at: 560)
Complexity:   |      77 |   *** | MONSTER |
CalledNBR:    |     189 |   *** | MONSTER |
LOC:          |     547 |   *** | MONSTER |
3 metric are OUT OF RANGE!
output_et (Begins at: 563 Ends at: 710)
Complexity:   |      17 |     * |         |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |      36 |     * |         |
LOC:          |     148 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
