[GRASS-QA] GRASS QA: jachym | ./grass6/raster/wildfire/r.spread/main.c |no clones | 3 monsters | 0 warnings
Sat Dec 9 13:54:33 EST 2006
Hello jachym,
ANALYSIS
raster/wildfire/r.spread/main.c functions
main (Begins at: 77 Ends at: 572)
Complexity:   |      64 |   *** | MONSTER |
CalledNBR:    |     221 |   *** | MONSTER |
LOC:          |     496 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
