[GRASS-QA] GRASS QA: markus | ./grass6/general/g.mapsets/main_cmd.c |no clones | 0 monsters | 0 warnings
Sat Dec 9 13:54:33 EST 2006
Hello markus,
ANALYSIS
general/g.mapsets/main_cmd.c functions
main (Begins at: 16 Ends at: 204)
Complexity:   |      16 |     * |         |
CalledNBR:    |      49 |     * |         |
LOC:          |     189 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
