[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.texture/h_measure.c |no clones | 1 monsters | 0 warnings
Sat Dec 9 13:54:31 EST 2006
Hello jachym,
ANALYSIS
raster/r.texture/h_measure.c functions
h_measure (Begins at: 68 Ends at: 246)
Complexity:   |      72 |   *** | MONSTER |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      65 |    ** | Warning |
LOC:          |     179 |     * |         |
1 metric are OUT OF RANGE!
MatrixDealloc (Begins at: 248 Ends at: 253)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
f1_asm (Begins at: 255 Ends at: 274)
CalledNBR:    |       0 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
f2_contrast (Begins at: 278 Ends at: 302)
Complexity:   |       2 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
f3_corr (Begins at: 305 Ends at: 351)
LOC:          |      47 |       |      OK |
metrics are OK
f4_var (Begins at: 355 Ends at: 375)
LOC:          |      21 |       |      OK |
metrics are OK
f5_idm (Begins at: 378 Ends at: 390)
LOC:          |      13 |       |      OK |
metrics are OK
f6_savg (Begins at: 395 Ends at: 413)
LOC:          |      19 |       |      OK |
metrics are OK
f7_svar (Begins at: 417 Ends at: 436)
ParamNBR:     |       3 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
f8_sentropy (Begins at: 439 Ends at: 458)
CalledNBR:    |       1 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
f9_entropy (Begins at: 462 Ends at: 474)
LOC:          |      13 |       |      OK |
metrics are OK
f10_dvar (Begins at: 478 Ends at: 503)
LOC:          |      26 |       |      OK |
metrics are OK
f11_dentropy (Begins at: 506 Ends at: 525)
LOC:          |      20 |       |      OK |
metrics are OK
f12_icorr (Begins at: 528 Ends at: 568)
CalledNBR:    |       7 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
f13_icorr (Begins at: 571 Ends at: 611)
CalledNBR:    |      10 |       |      OK |
LOC:          |      41 |       |      OK |
metrics are OK
f14_maxcorr (Begins at: 614 Ends at: 663)
CalledNBR:    |       9 |       |      OK |
LOC:          |      50 |       |      OK |
metrics are OK
vector (Begins at: 666 Ends at: 674)
CalledNBR:    |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
matrix (Begins at: 678 Ends at: 701)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
simplesrt (Begins at: 704 Ends at: 720)
LOC:          |      17 |       |      OK |
metrics are OK
mkbalanced (Begins at: 723 Ends at: 770)
Complexity:   |       7 |       |      OK |
LOC:          |      48 |       |      OK |
metrics are OK
reduction (Begins at: 774 Ends at: 815)
Complexity:   |       5 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
hessenberg (Begins at: 818 Ends at: 975)
Complexity:   |      22 |     * |         |
CalledNBR:    |      30 |       |      OK |
LOC:          |     158 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
