[GRASS-QA] GRASS QA: markus | ./grass6/lib/gmath/dalloc.c |2 clones ( color_get.c dalloc.c dalloc.c main.c main.c main.c parser.c main.c main.c main.c count.c main.c main.c o_kurt.c o_skew.c topmodel.c areas.c parser.c dalloc.c )| 0 monsters | 0 warnings
Sat Dec 9 13:54:34 EST 2006
Hello markus,
ANALYSIS
lib/gmath/dalloc.c functions
G_alloc_vector (Begins at: 15 Ends at: 30)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
G_alloc_matrix (Begins at: 32 Ends at: 53)
CalledNBR:    |       2 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G_alloc_fvector (Begins at: 55 Ends at: 70)
LOC:          |      16 |       |      OK |
metrics are OK
G_alloc_fmatrix (Begins at: 72 Ends at: 93)
LOC:          |      22 |       |      OK |
metrics are OK
G_free_vector (Begins at: 95 Ends at: 110)
LOC:          |      16 |       |      OK |
metrics are OK
G_free_matrix (Begins at: 112 Ends at: 128)
LOC:          |      17 |       |      OK |
metrics are OK
G_free_fmatrix (Begins at: 130 Ends at: 135)
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  G_alloc_fmatrix  G_alloc_matrix
In lib/gmath/dalloc.c clones of  G_alloc_fmatrix are:
	lib/gmath/dalloc.c  G_alloc_matrix
In lib/gmath/dalloc.c clones of  G_alloc_matrix are:
	lib/gmath/dalloc.c  G_alloc_fmatrix
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
