[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.out.vrml/put_grid.c |no clones | 1 monsters | 0 warnings
Sat Dec 9 13:54:27 EST 2006
Hello jachym,
ANALYSIS
raster/r.out.vrml/put_grid.c functions
vrml_put_grid (Begins at: 9 Ends at: 160)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      54 |     * |         |
LOC:          |     152 |     * |         |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
