[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.report/format.c |no clones | 0 monsters | 0 warnings
Sat Dec 9 13:54:28 EST 2006
Hello jachym,
ANALYSIS
raster/r.report/format.c functions
format_parms (Begins at: 15 Ends at: 48)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       4 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
scient_format (Begins at: 50 Ends at: 60)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
format_double (Begins at: 62 Ends at: 77)
CalledNBR:    |       7 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
