[GRASS-QA] GRASS QA: hamish | ./grass6/raster/r.report/prt_report.c |no clones | 1 monsters | 0 warnings
Sat Dec 9 13:54:23 EST 2006
Hello hamish,
ANALYSIS
raster/r.report/prt_report.c functions
print_report (Begins at: 5 Ends at: 275)
Complexity:   |      28 |    ** | Warning |
CalledNBR:    |      38 |     * |         |
LOC:          |     271 |   *** | MONSTER |
1 metric are OUT OF RANGE!
construct_val_str (Begins at: 277 Ends at: 309)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
construct_cat_label (Begins at: 311 Ends at: 339)
CalledNBR:    |       7 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
