[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.sunmask/solpos00.c |no clones | 0 monsters | 0 warnings
Sat Dec 9 13:54:30 EST 2006
Hello jachym,
ANALYSIS
raster/r.sunmask/solpos00.c functions
S_solpos (Begins at: 182 Ends at: 262)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      81 |       |      OK |
metrics are OK
S_init (Begins at: 264 Ends at: 287)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
validate (Begins at: 295 Ends at: 374)
Complexity:   |      22 |     * |         |
CalledNBR:    |       7 |       |      OK |
LOC:          |      80 |       |      OK |
metrics are OK
dom2doy (Begins at: 376 Ends at: 401)
Complexity:   |       2 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
doy2dom (Begins at: 403 Ends at: 423)
Complexity:   |       3 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
geometry (Begins at: 431 Ends at: 594)
Complexity:   |       9 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |     164 |     * |         |
metrics are OK
zen_no_ref (Begins at: 596 Ends at: 626)
Complexity:   |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
ssha (Begins at: 628 Ends at: 660)
Complexity:   |       5 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
sbcf (Begins at: 662 Ends at: 681)
LOC:          |      20 |       |      OK |
metrics are OK
tst (Begins at: 683 Ends at: 702)
LOC:          |      20 |       |      OK |
metrics are OK
srss (Begins at: 710 Ends at: 732)
LOC:          |      23 |       |      OK |
metrics are OK
sazm (Begins at: 734 Ends at: 768)
CalledNBR:    |       5 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
refrac (Begins at: 770 Ends at: 818)
CalledNBR:    |       4 |       |      OK |
LOC:          |      49 |       |      OK |
metrics are OK
amass (Begins at: 820 Ends at: 846)
CalledNBR:    |       2 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
prime (Begins at: 848 Ends at: 852)
CalledNBR:    |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
etr (Begins at: 860 Ends at: 870)
LOC:          |      11 |       |      OK |
metrics are OK
localtrig (Begins at: 878 Ends at: 901)
Complexity:   |       7 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
tilt (Begins at: 909 Ends at: 946)
LOC:          |      38 |       |      OK |
metrics are OK
S_decode (Begins at: 948 Ends at: 1004)
Complexity:   |      19 |     * |         |
CalledNBR:    |      18 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
