[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.topmodel/misc.c |no clones | 0 monsters | 0 warnings
Sat Dec 9 13:54:32 EST 2006
Hello jachym,
ANALYSIS
raster/r.topmodel/misc.c functions
run (Begins at: 5 Ends at: 20)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
gregion (Begins at: 24 Ends at: 48)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
depressionless (Begins at: 52 Ends at: 67)
LOC:          |      16 |       |      OK |
metrics are OK
basin_elevation (Begins at: 71 Ends at: 84)
LOC:          |      14 |       |      OK |
metrics are OK
top_index (Begins at: 88 Ends at: 115)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
