[GRASS-QA] GRASS QA: markus | ./grass6/db/drivers/postgres/db.c |no clones | 0 monsters | 1 warnings
Sat Dec 9 13:54:33 EST 2006
Hello markus,
ANALYSIS
db/drivers/postgres/db.c functions
db__driver_open_database (Begins at: 8 Ends at: 147)
Complexity:   |      25 |     * |         |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      73 |    ** | Warning |
LOC:          |     140 |     * |         |
at least 1 values are close to an outlier please consider revising code
db__driver_close_database (Begins at: 149 Ends at: 154)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
