[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/r3.in.ascii/main.c |1 clones ( color_get.c dalloc.c dalloc.c main.c main.c main.c parser.c main.c main.c main.c count.c main.c main.c o_kurt.c o_skew.c topmodel.c areas.c parser.c dalloc.c mask_functions.c main.c )| 0 monsters | 0 warnings
Sat Dec 9 13:54:36 EST 2006
Hello markus,
ANALYSIS
raster3d/r3.in.ascii/main.c functions
fatalError (Begins at: 50 Ends at: 59)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
setParams (Begins at: 70 Ends at: 91)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
getParams (Begins at: 96 Ends at: 107)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
readHeaderString (Begins at: 112 Ends at: 124)
ParamNBR:     |       3 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
openAscii (Begins at: 129 Ends at: 157)
CalledNBR:    |      15 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
asciiToG3d (Begins at: 164 Ends at: 220)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      25 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
main (Begins at: 224 Ends at: 286)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |      63 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  fatalError
In raster3d/r3.in.ascii/main.c clones of  fatalError are:
	lib/g3d/g3dclose.c  G3d_closeOld
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
