[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.random.surface/save.c |no clones | 0 monsters | 1 warnings
Sat Dec 9 13:54:28 EST 2006
Hello jachym,
ANALYSIS
raster/r.random.surface/save.c functions
SaveMap (Begins at: 12 Ends at: 219)
Complexity:   |      23 |     * |         |
CalledNBR:    |      23 |       |      OK |
LOC:          |     208 |    ** | Warning |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
