[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.to.rast3/main.c |1 clones ( color_get.c dalloc.c dalloc.c main.c main.c main.c parser.c main.c main.c main.c count.c main.c main.c o_kurt.c o_skew.c topmodel.c areas.c parser.c dalloc.c mask_functions.c main.c main.c main.c main.c main.c )| 0 monsters | 0 warnings
Sat Dec 9 13:54:38 EST 2006
Hello markus,
ANALYSIS
raster/r.to.rast3/main.c functions
fatal_error (Begins at: 49 Ends at: 68)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
set_params (Begins at: 73 Ends at: 89)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
raster_to_g3d (Begins at: 96 Ends at: 167)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      72 |       |      OK |
metrics are OK
main (Begins at: 173 Ends at: 345)
Complexity:   |      22 |     * |         |
CalledNBR:    |      55 |     * |         |
LOC:          |     173 |     * |         |
metrics are OK
open_input_raster_map (Begins at: 352 Ends at: 367)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
close_input_raster_map (Begins at: 372 Ends at: 376)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In raster/r.to.rast3/main.c clones of  open_input_raster_map are:
	raster3d/r3.out.vtk/main.c  open_input_map
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
