[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.statistics/o_adev.c |no clones | 0 monsters | 0 warnings
Sat Dec 9 13:54:29 EST 2006
Hello jachym,
ANALYSIS
raster/r.statistics/o_adev.c functions
o_adev (Begins at: 11 Ends at: 89)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      15 |       |      OK |
LOC:          |      79 |       |      OK |
metrics are OK
a_dev (Begins at: 92 Ends at: 117)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
