[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.to.rast3elev/main.c |1 clones ( color_get.c dalloc.c dalloc.c main.c main.c main.c parser.c main.c main.c main.c count.c main.c main.c o_kurt.c o_skew.c topmodel.c areas.c parser.c dalloc.c mask_functions.c main.c main.c main.c main.c )| 0 monsters | 1 warnings
Sat Dec 9 13:54:38 EST 2006
Hello markus,
ANALYSIS
raster/r.to.rast3elev/main.c functions
get_raster_value_as_double (Begins at: 64 Ends at: 94)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      31 |       |      OK |
metrics are OK
check_input_maps (Begins at: 99 Ends at: 146)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      48 |       |      OK |
metrics are OK
open_input_raster_map (Begins at: 151 Ends at: 164)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
close_input_raster_map (Begins at: 169 Ends at: 173)
LOC:          |       5 |       |      OK |
metrics are OK
fatal_error (Begins at: 178 Ends at: 195)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
set_params (Begins at: 200 Ends at: 236)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
elev_raster_to_g3d (Begins at: 241 Ends at: 375)
Complexity:   |      22 |     * |         |
CalledNBR:    |      33 |       |      OK |
LOC:          |     135 |     * |         |
metrics are OK
main (Begins at: 380 Ends at: 555)
Complexity:   |      18 |     * |         |
CalledNBR:    |      62 |    ** | Warning |
LOC:          |     176 |     * |         |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file has 1 potentially cloned functions:
In raster/r.to.rast3elev/main.c clones of  get_raster_value_as_double are:
	raster3d/r3.out.vtk/writeVTKData.c  get_raster_value_as_double
	raster/r.out.vtk/writeascii.c  get_raster_value_as_double
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
