[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.statistics/read_stats.c |no clones | 0 monsters | 0 warnings
Sat Dec 9 13:54:40 EST 2006
Hello martinl,
ANALYSIS
raster/r.statistics/read_stats.c functions
read_stats (Begins at: 5 Ends at: 22)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
