[GRASS-QA] GRASS QA: markus | ./grass6/lib/form/generate.c |no clones | 2 monsters | 0 warnings
Sat Dec 9 13:54:34 EST 2006
Hello markus,
ANALYSIS
lib/form/generate.c functions
F_generate (Begins at: 14 Ends at: 229)
Complexity:   |      20 |     * |         |
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |     107 |   *** | MONSTER |
LOC:          |     216 |    ** | Warning |
2 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
