[GRASS-QA] GRASS QA: jachym | ./grass6/raster/r.series/main.c |1 clones ( color_get.c dalloc.c dalloc.c main.c main.c main.c parser.c main.c main.c main.c count.c main.c main.c )| 0 monsters | 0 warnings
Sat Dec 9 13:54:29 EST 2006
Hello jachym,
ANALYSIS
raster/r.series/main.c functions
build_method_list (Begins at: 42 Ends at: 59)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
main (Begins at: 61 Ends at: 230)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      52 |     * |         |
LOC:          |     170 |     * |         |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  build_method_list
In raster/r.series/main.c clones of  build_method_list are:
	raster/r.resamp.stats/main.c  build_method_list
Threshold GRASS6 key metrics values at 2006-12-09 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
