[GRASS-QA] GRASS QA: jachym | ./grass6/vector/v.to.db/update.c |no clones | 1 monsters | 0 warnings
Mon Dec 11 13:03:01 EST 2006
Hello jachym,
ANALYSIS
vector/v.to.db/update.c functions
update (Begins at: 11 Ends at: 203)
Complexity:   |      49 |   *** | MONSTER |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      43 |     * |         |
LOC:          |     193 |    ** | Warning |
1 metric are OUT OF RANGE!
srch (Begins at: 205 Ends at: 213)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-12-11 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
